battery drain
Old 05-02-2013, 06:33 AM
chris1_uk's Avatar
Default battery drain
hi guys i did try looking for an old post on subject but couldnt see one
on my 2004 crossfire the battery keeps draining, ive tried putting a brand new battery but after a short while again the battery drains
would be very greatfull if someone might have a few ideas for me to see what is causing the drain
cheers chris
Old 05-02-2013, 06:55 AM
Default Re: battery drain
see https://www.crossfireforum.org/forum...questions.html
Maybe you have the same issue ?
Old 05-02-2013, 07:03 AM
chris1_uk's Avatar
thanks alax will check that out
Old 09-16-2013, 04:12 PM
I had the same problem and wrote several threads about the subject. It is solved by 1) replacing the battery and 2) disconnecting the antitheft module in the trunk. Apparently, the antitheft device (below the foam matt in the trunk) was draining by working all the time. Just unplug the electrical harness goes to it, you find the difference in drainage. Good Luck
Old 09-16-2013, 04:23 PM
cheers chris
What time frame are we talking hours, days or weeks?
You should check all the other fuses after checking the fuse #9, put a digital voltmeter set to Ma across the two terminals that the fuse connects. There are posts on this.
Add up all the readings, there is a number (35 Ma) that this should not exceed, I think that is the number mentioned in the link. Some fuses will have no reading and others a small amount which keeps the memory alive etc in some accessories or parts.
Old 09-16-2013, 05:12 PM
cheers chris
Are you SURE the alternator is charging? A simple voltmeter plugged into the lighter outlet will show you if it is. If it is, (and Im sure it is - but since I'm not there, I thought I better mention that) then:
Take a battery cable off, and put a meter in series with it and see for yourself what is REALLY going on.
The manual says that 35 mA, that is, .035 amp, is normal. If you measure more than that, start pulling fuses until the the current goes down - you will isolate it to a single fuse, usually, in no time. THEN the real work may start.
Old 09-28-2013, 09:41 PM
Please email me the bottom line b/c I will probably find this again...that's how bad I am on the computer. So after disconnecting trunk security solved the problem I hope so. I was told that the sensor needs to be reset???? Please give me your info via email at: pstachler@gmail.com
THANKS
Old 09-28-2013, 09:50 PM
Email sent
syfi
12-11-2023 07:31 PM
blackpepper
10-04-2017 06:09 AM
o55ie18
10-05-2015 05:50 PM
rmcdaniel12
09-22-2015 01:20 PM
Valk
09-17-2015 11:43 AM
Quick Reply: battery drain
