Skreem module installation ???
Re: Skreem module installation ???
Originally Posted by jpeez20
Does anyone have a step by step guide to install a skreem module for a 04 crossfire .? Or any links .?
This is what I did to get the stupid thing to shut up. I just unplugged mine and never went back to replace it. Mine went bad three and a half states from home, figured if I replaced it I was just setting myself up for that again. Search under skreem and you may find a better description of how to do this. Have fun.
Originally Posted by ZORRO
I do not have picks. But what you do is remove the nuts then get a small gear puller to remove the wiper arms (yes on mine at least they are were on that tight) Then undo the torques/sp? bolts along the front of the panel under the wiper arms (just kind of pulls out of a gasket at the windshield) them right about the center of the firewall you will see what looks like a horn pointing up (cant mis it)
The instructions are in the Shop Manual, to be found here.
https://www.crossfireforum.org/forum...tml#post111722
These instructions put you on the wrong side of the firewall, the SKREEM module is under the dash inside the car.
PS whatever happened to the $3,000 bill? We like feedback on here. WIN module?
Oh sorry about that..well chrysler told me that I needed a win module and new key ..so I began ordering parts as soon as they told me this because I haven't had my car in a month. The win module is the same as the skreem module ..just another word for it. Win means wireless ignition node ..either way my car isn't starting ad I wanted to see if there was someone outside of chrysler who would fix this ..but everyone says no. Hopefully its just the win module and nothing else ...only had the car for 2 weeks ..lucky me. The diagnoses from chrysler was that I needed those two parts skreem and a new key ..so we will find out tomm.if this is true. Everything turns on in my car but the engine..
REYMARTZ
22
08-07-2021 12:37 PM
jhansen
21
02-15-2017 04:26 PM
x1xsinisterx1x
08-24-2015 07:31 PM
