car loses power at high rpms
Old 08-28-2011, 10:21 PM
buniqueXF's Avatar
Default car loses power at high rpms
Heres the problem, when i accelerate the car any kind of spirited it will lose total power either in the upper rpms of second gear or right after i shift to third. Now let me be clear the car does not stall or die out.....it is still running, it is just idling and will not rev if i step on the gas..... if i turn the car off and back on it will continue to run fine until i rev it up hard again in second. Has anybody experienced anythng like this? It is very annoying and my neck is getting sore from the sudden power loss haha....oh its an 04 limited 6-speed
Old 08-28-2011, 10:25 PM
Default Re: car loses power at high rpms
Mine ran like this when the fuel pump started failing.
I also had difficulty starting the car....long crank times.
Old 08-29-2011, 07:36 AM
Assuming you are not hitting the rev limiter, I would agree with Valkryderguy.
Unless you have had it modified, the engine will cut out completely at 5740 RPMs.
roadster with a stick
Old 08-29-2011, 07:51 AM
In gear it will die at 6,000rpm and in neutral at a lesser rpm (4,000? maybe less, I never did it,)
These are the OEM specs.
Old 08-29-2011, 08:20 AM
Chris L.'s Avatar
The rev-limiter must be at least 6000 (moving) since the car magazines tested the 6 speed to 6000 rpms in each gear (except 6th gear) & the quasi-launch control feature is set to 4200 rpms...clutch in, dead stop, drop clutch.
Old 08-29-2011, 01:34 PM
buniqueXF's Avatar
its not the rev limiter, ive hit that before and it only stops for a seconduntil im back at a resonable rpm. this wont let me rev at all until i turn the car off and back on
Old 08-29-2011, 02:28 PM
5740 according to the guys who actually worked on my engine.
I guess they should have read the maual before they looked at the computer screen.
Until I hear different that them,the owners manual sucks.
Old 08-29-2011, 02:38 PM
buniqueXF's Avatar
i also forgot to mention that when this happens the bas\esp light comes on
Old 08-29-2011, 03:18 PM
I'm still gonna go with fuel pump.
Once the Engine management system shuts things down it must reset
The fuel pumps seems to be a recurrent problem with these cars. I repalced mine and several others have had to replace theirs. The frequency is abnormal but don't look for a Chrysler recall.
It will not get better so look into it soon.
Old 08-30-2011, 06:11 AM
Chris L.'s Avatar
I'll have to admit, anytime my tach gets close to the redline my attention is focused in the direction of the windshield......I did test the 4200 rpm launch feature once & ....4200 was where it stopped....
Old 08-30-2011, 09:30 AM
6k on mine - could do with another 500 I reckon!
Old 08-30-2011, 09:32 AM
If the bas/esp light comes on then maybe it is to do with the speed sensors in one of the wheels, power is cut to the engine when that system is actuated.
As it seems to be speed related, I suspect something that measures rpm and the bas/esp does this, possibly one of the wheel sensors fails to match the output of the other three.
Old 08-30-2011, 10:32 AM
user 8202's Avatar
Banned
Yep...twice in the three years I have owned the car. Both times I was pushing it very hard with high rpm's. I am assuming it's the engine management system doing what it's suppose to do...car runs like a dream.
Old 08-31-2011, 07:02 PM
Not sure about the rev limiter, i have pushed my car well pass 6000 rpm with no shut down, i also drive car with traction control off at all times. I had a issue when i first bought my crossfire of mystery shut down under normal conditions, trouble shoot from fuel filter, fuel pump, and result replaced the rcm car has been perfect, the rcm is a very common malfunction in the crossfire, good luck
Old 09-01-2011, 09:23 PM
Just have to start looking at all things in line with what you are doing... Throttle Control Module... comes to mind... throttle signal interrupted for some reason would result in temporary loss of throttle... I have heard on the N/A's, that throttle problems can be linked to a dirty MAP sensor...
Old 09-08-2011, 01:33 AM
Heres the problem, when i accelerate the car any kind of spirited it will lose total power either in the upper rpms of second gear or right after i shift to third. Now let me be clear the car does not stall or die out.....it is still running, it is just idling and will not rev if i step on the gas..... if i turn the car off and back on it will continue to run fine until i rev it up hard again in second. Has anybody experienced anything like this? It is very annoying and my neck is getting sore from the sudden power loss haha....oh its an 04 limited 6-speed
Sounds like a clutch problem. When the clutch that transfers engine power to the means of transmission, so that he can no longer entrust this power example is the torque, it will really start to drag, which increases the motor speed and lose power to your wheels. The remedy is to replace the clutch. check out the list of tsb for more info about recalls and tsb's .
Old 02-07-2015, 05:45 AM
My 06 crossfire wo,nt accelerate past 4000 rpm had it to local garage says car fine mite be computer needs update ,?
Old 02-22-2015, 02:26 PM
Toolman's Avatar
Another member recently reported a similar problem. It turned out to be the fuel pump relay in the RCM. The fuel pump worked enough to start the car but the faulty relay (burnt contacts) would cause it to cut out under load.
Old 01-30-2020, 03:55 PM
My 04 crossfire will run ruff when i try to drive it hard. It feels like its got a misfire untill i turn the key off. When i start it back up runs fine. I get a p0172 and p0175 code. If i i drive easy the light resets itself.
Old 01-30-2020, 05:38 PM
What is your mileage? Have you ever changed plugs?
Quick Reply: car loses power at high rpms
