Does Anybody Know What Bas Esp On The Dashboard?
Old 12-22-2009, 10:57 PM
kussh's Avatar
Default Does Anybody Know What Bas Esp On The Dashboard?
Turn My Car On In The Morning Drove Off And The Bas Esp Light When On Does Any Body Know What This Means?thanxs
Old 12-24-2009, 09:18 AM
32krazy!'s Avatar
Default Re: Does Anybody Know What Bas Esp On The Dashboard?
turn your wheel all the way to the left and then to the right. then center. the light will go out
bas/esp is brake assist system/ electronic stability program
Old 12-24-2009, 05:03 PM
The Crossfire owners manual says that the dealership should investigate the reason why the light came on if the above reset does not work. The reset mentioned only works after a battery has been disconnected and then reconnected, and is not a cure all.
Old 12-24-2009, 09:51 PM
32krazy!'s Avatar
sorry didnt mean to imply it was a fix all. assuming that codes were checked and using the lock to lock method to reset the bas/esp after.
and defining the abbreviations
xfClifford
27
11-10-2015 10:08 PM
Reliableron
10-17-2015 10:19 PM
velociabstract
15
09-07-2015 03:43 PM
joethejeweler
07-07-2015 08:58 PM
Blackout317
07-07-2015 08:38 PM
Quick Reply: Does Anybody Know What Bas Esp On The Dashboard?
