Master list for MB/Crossfire part numbers
Old 09-01-2009, 07:10 PM
Default Master list for MB/Crossfire part numbers
A new "sticky" thread.....
As a result of another thread started here on the forum I will attempt to create and manage a list of MB/Crossfire part numbers for the benefit of everyone here on the forum.
As a moderator here I have the ability to edit and add info etc.
I don't have the time to search the threads but will post the info if it is provided to me in a PM in a format which I can copy and paste directly into this thread.
Please keep it brief:
Part Description
Mercedes Part Number
Crossfire Part Number
I'll give it a try if we all work together.
Old 09-01-2009, 07:12 PM
Default Re: Master list for MB/Crossfire part numbers
Transmission electrical connectors (leaky ones)
Electrical connector shell (with 2 O-Rings)
MB 2035400253
Crossfire 68021352AA
Electrical connector insert (with 1 O-ring) goes inside of above connector and can also leak
MB 0015409981
Crossfire
unknown
________________________________________
Trans Fluid
MB 001989680310
Crossfire 05127382AA
Siren/Alarm
Mercedes#A171 820 25 26
Crossfire# 56038724AB
Plastic lock pin (for dipstick hole)
MB 1409910055
Crossfire
unknown
Old 09-23-2009, 10:23 PM
Provided by member lugNut......
Wiper pivot-to-cowl grommet/seal/isolator, black
MB 1708240098
DC 5101283AA
Wiper arm-to-pivot nut cap, black
MB 0008240249
DC 5101489AA
Washer reservoir/tank
MB 1708690320
DC 5096729AA
Lug bolt locks, set of four
MB Q6408113
DC 82208313
Transmission check/fill tube lock
MB 1409910055
DC 5093746AA
Oil filter cap assembly, with filter and o-rings
MB 1121800710
DC 5114263AA
License plate light assembly, with lens and bulb
MB 2308200256
DC 5099804AA
Old 10-16-2009, 11:08 AM
Provided by "onehundred80"
Relay Cointrol Module
MB #170 545 03 05
Mopar #5099007AA
Old 10-16-2009, 10:15 PM
Provided by TexasT
Lock cylinder key housing
MB # 2024600904
chr # 68001655aa
Old 10-17-2009, 07:53 PM
Provided by TexasT
Rear brake pads non srt
MB 0034202720
Mopar 5126300AA
All oem CAI air filter
MB 112 094 0304
Mopar 5098424AA
Old 12-24-2009, 07:16 PM
Provided by onehundred80
Multi function Tool
Chrysler part #5140795AA
MB parts #A 193 899 03 80 or
#A 193 899 02 80
Old 01-01-2010, 02:46 AM
Provided by rekcah
pdf file
Old 01-06-2010, 06:43 PM
Provided by Guy Wagon
MB oil filter wrench.
MB part # 103 589 02 09 00
Old 02-02-2010, 03:51 PM
Chrysler......Tie rod linkage PN# 05098996AA
Mercedes... Drag link PN# 170 463 01 15
Old 02-20-2010, 01:24 AM
Provided by: onehundred80
Secondary air injection system check valve.
MB#A002 140 8460 (was #A001 140 6660)
Mopar#5096374AC (was #50963374AC)
Old 03-13-2010, 01:17 AM
Part Description: Rocker panel clip (white, 5 required per panel)
Mercedes Part Number, A 170 988 08 78
Crossfire Part Number, 05101311AA
Nynick8 (10-19-2022)
Old 04-22-2011, 09:56 PM
Water Pump
Mercedes part#112 200 1501
Chrysler part# 05097159AC ?
or #05097158AA ?
Bosch part# 99176
Old 06-30-2011, 08:00 PM
Provided by amx1397
Central Locking Pump module for a Chrysler Crossfire 2004 -2008
or Mercedes Benz SLK 2004 - 2008.
The Chrysler part number is 05102774AA
The Mercedes Benz part number is 170 800 08 48
Old 07-10-2011, 08:33 PM
Water Pump - n/a
Mercedes part#112 200 15 01
Bosch part# 99176
Water Pump - SRT6
Mercedes part#112 200 13 01
Chrysler part# 05102894AA
Old 07-11-2011, 06:55 PM
Provided by: dedwards0323
Description:
Gasket, Air Filter
(rubber gasket located at rear of air filter housing; seals to throttle body inlet)
M-B P/N: 112 094 01 80
Chrysler P/N: not listed
Old 08-27-2011, 05:43 AM
Provided by zip439
FUEL FILTER;
Chrysler number 5097052AA $116
MB number 002 477 30 01 $62
STEERING DAMPER, shock absorber;
Chrysler (old) number 5097971AA
Chrysler (old) number 68032068AA $112
MB number 124 463 04 32 $67
Old 10-08-2011, 09:06 PM
Clockspring
Mercedes part #A168 460 01 49
Chrysler part #5101577AA
Old 11-13-2012, 06:44 PM
Default Re: MB/Crossfire part numbers
Originally Posted by hpmotors
ECU Relay Box cooling fan - Chrysler Part 0509008 AA / MB Part 170 545 0095
Finally had to pull the fan out to get the part number.
Then did a lot of calling around and web crawling to discover that this number is not particularly useful at this time, as the Chrysler part is
1) available and
2) cheaper by about $40.
Old 11-13-2012, 07:07 PM
Originally Posted by rekcah
I found this Russian (I think) site that is similar to the crossfire parts pdf.
You might have to use a translator, if your browser doesn't automatically translate it for you.
This is for SLK320 ROADSTER NORTH AMERICA
Mercedes Benz EPC 170.465 Chassis Information | Everything Benz
EDIT: Actually I just found this other site which I think is better than the other one.
BMW parts and BMW OEM auto parts online
Quick Reply: Master list for MB/Crossfire part numbers
