BAS ESP light. What exactly is it?
I just bought by Xfire 1 week and a day ago. It is very low mileage, (7,015), when I bought it. It now has 8,700 as I have been on a couple of road trips over the week. Everything seems to be great with the car. It looks new inside and out and seems to drive like a new car. Periodically however the BAS ESP light will come on. Some times it is right after the car has been started, other times I can drive for 300 miles or more before it comes on, and at other times it never comes on at all. Another thing I have noticed is that over the course of the last week, maybe 3 or 4 times, the key will not rotate all the way to start the car. If I remove the key and insert again and rotate the car starts right up.
I did a search and found one guy who had replaced some fuses and fixed the problem. I guess what I am asking is this a problem at all. What is the BAS ESP light? I have reset the car by turning the steering wheel and the light goes off, however it will come back on sometime later. Am I looking at repairs here?
Re: BAS ESP light. What exactly is it?
As crazy as it may seem, check your tire pressures. We had the same issue with our red xfire and found that one tire can be low enough to set off the BAS/ESP light and not the low tire light. A slightly low tire messes with the electronic stability control. Works everytime now.
You may want to hook up an OBDII reader and check for any codes if you can. This is also very helpful in troubleshooting.
Hmmmm thanks for the tip. I just checked the air pressure this evening, after letting the car cool down for a few hours. I have 31 PSI in both the fronts and 33 PSI in both of the rear tires. I just made a 600 mile round trip over the past 5 days. On the way I think I the light came on once. After I arrived and made several short trips around town over the last few days the light came on periodically. On the way back home the light came on and stayed on for 100 miles or so. After stopping at a gas station I didnt see the light again today. Weird. I did experience the ignition locking up on me again, in the sense that it wont let me turn the key far enough to start the car. I'm going to see if a buddy of mine has an OBD reader for these newer cars.
FWIW, I had the same symtoms, however I don't have any ignition issues. You don't mention the year of your Crossfire, but if it is an '04 or '05 regardless of mileage, you can expect sensors to start failing as the batteries in them will start losing voltage, messing up the TPMS system with false warnings. You don't mention if your TPMS (low pressure) lamp is on. If so, you have the exact symptoms as I had. Replacing my sensors with new fixed the problem. BTW I was not reading any codes at the time when using a OBDII reader.
Let us know what fix solves the problem.
There are several threads here regarding ignition switches that go bad
My background is Volvo and we have a history of shiftlocks failing, rendering the stuck key in lock position.
I am finding a lot of similiarities between the MB made Crossfire and our Belgium made Volvo's. Things like locks, alarms, DRL's, mostly electrical stuff. The Europeans do things differently, but all do it the same.
Hello Guys,
I have a 2004 Chrysler Crossfire and I am struggling with sensors.
After changing the crankshaft Position Sensor and the Camshaft Position sensor because the car was stopping by itself, I am now struggling with BAS/ESP.
The gear box is stuck on P and even though I managed to move gear manually I would like to know your experiences.
To be more accurate, while driving the car I noticed a small noise pushing brake. Thus I was thinking that might brake switch.
Did you guys face this issues and moreover is changing the brake switch usefull?
Thank you
Thank you
Following the manual page 151 bas esp turning the wheel full left and right and center did the trick. Now off to the treated P0410 code
QUOTE=ppro;391822]See the manual...p135
More here...[/QUOTE]
sorry. i fell asleep with hand on keyboard while researching BAS:ESP light on
unable ttto reset lock left lock right
also traction switch has no effect when pressed
Last edited by aussieguy; 09-17-2020 at 04:36 AM. Reason: fell asleep reading about bsa/esp
