Can I put Regular Unleaded Gas in my Crossfire?
Re: Can I put Regular Unleaded Gas in my Crossfire?
Originally Posted by trent_850
Hey, I was wondering is there any way I can put Regular Unleaded (87) gas in my car instead of Premium (92) and the car would still run fine. Or do I need a special type of fuel injection? Can anyone please help me out?
Yes, you can use regular.
You can expect worse gas mileage, thereby negating any type of financial gain.
You can also expect to replace the catalytic converters sooner than expected.
You can also expect a loss of power due to the PCM pulling spark advance WAYYYYYY back to keep your engine from fitting loosely in a 5 gallon bucket.
Hope this helps.
Hope this helps.
But you can run regular gas if that is all you can find. When I picked up my crossfire new from the dealer they told me to pull it up to their pump and they filled my tank for FREE. They only had one gas pump and I am pretty sure it was not 93 octane. It ran fine and got me home ok. I won't use it everyday but it will get you by in a pinch.
High compression engines don't like low octane gas !!! It's your car do as you wish, but if the reason you're contemplating a lower octane is price ??? As stated already you'll be making up for the cost savings later !
Just my Dos Centavos !
This topic has been discussed to death. If you want to do a search you can read all the arguments, but in a nut shell, The car requires premium, the cost difference in a fill up assuming it's completely empty is only about $3. Not worth the repairs you may injure on repairs later on.
The crossfire (don't know about the srt-6) actually only requires 91 (most pump stations sell 93, but 91 is the lowest to be considered premium). If you were to use 87, I would imagine an octane booster would help, but they cost about as much as your saving.
My advice, 93 with octane booster.
OOORRRR.... How about 100?
Will 100 work better in my vehicle than 93, without any modifications?
Originally Posted by IRSmurf
Is there an upper limit to this?
Originally Posted by Sandgrounder
Premium, its a no brainer. 16 gallons 30/40 cents per gallon extra ,5 bucks a tank max
What's the old saying ... If you have to ask how much it costs, you can't afford it!! 5 Bucks a tank is a drop in the bucket next to oil changes, tires & god forbid any repairs you would need if you didn't run the right fuel. Just follow what Chrysler says - if you wanted to run 87 you should have gotten a Honda.
Steve D
01-09-2024 02:21 PM
